Where do I go to add the delta, radius, tangent, and c values of an alignment at a particular station? I have tried line and curve labeling but it is only letting me add the bearing and distance. I have the curve label style set up but can't add it.
Solved by MMcCall402. Go to Solution.
All I can say is I've never had any trouble. You should be able to and anything from the list in the Label Style Composer. Could you show a screenshot of when you try to add them? Or post the drawing?
Allen Jessup
CAD Manager - Designer
I don't think you can label curves with that data. For alignments you can label the intersection of the tangents with that data, but choose to label alignments, not lines and curves.
Same dialog you posted, change the "Feature" dropdown from Line and curve to alignment. And label type to intersection.
Here is the .dwg file. Mainly trying to add it to Golfhill Drive P&P and Golfhill Drive (2) P&P
I downloaded the file and was able to label the alignment with the label styles provided. If I picked a line segment, I got a line label. When I picked a curved segment, I got a curve label.
I also set the label type to Multiple, selected the alignment and it applied labels to all the segments, lines and curves.
Line and curve labels are functioning as they should in the file provided.
Yeah I see that now for the multiple segment part. I was just having trouble picking and singling out the curve segments.
