Delta Label Style issues.
HeathMMGHGS
Message 1 of 17
HeathMMGHGS
I can not figure out how to get my label style for  "Distance-Radius and Delta" to display a D=DDMMSS. It ads the weird characters for minutes and seconds as seen in screenshot 1. The preview in label style editor (screenshot2), however, shows it how I want it. Does any one know how to fix that?
Accepted solutions (3)
Replies (16)
Message 2 of 17
tcorey
It could be in the font you use in the first screenshot. Use something common, like Arial or TimesNewRoman.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 17
HeathMMGHGS
I did try that, but to no avail.
Message 4 of 17
Pointdump
Hi Heath,
Welcome to the Autodesk Forums.
Please post your drawing.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 17
HeathMMGHGS
The drawing is attached...
Message 6 of 17
SoaresASBCAD
Message 7 of 17
Pointdump
Heath,
Thanks for posting your drawing.
Because of the font coding in the Content Editor, I couldn't change the font from "fSymbol" to something else without deleting that component and re-creating. Of course then you lose the Delta Symbol.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 17
HeathMMGHGS
I found the code for what I was looking for. It is shown in the attached screenshot. Thank you so much for the help.
Message 9 of 17
HeathMMGHGS
L=<[General Segment Length(Uft|P4|RN|AP|GC|UN|Sn|OF)]>, R=<[General Segment Curve Radius(Uft|P2|RN|AP|GC|UN|Sn|OF)]>
CH.L.:<[General Segment Curve Chord Length(Uft|P2|RN|AP|GC|UN|Sn|OF)]>,  CH.B.:<[General Segment Curve Chord Direction(Udeg|FDMSd|MB|P4|RN|DSn|CU|AP|EN|DZY|OF)]>
Message 10 of 17
HeathMMGHGS
it was the "Symbol" font. once I changed that, the delta symbol changed to a "D". Thank you. That was helpful!
Message 11 of 17
ChrisRS
Thanks for posting the drawing.
I just looked back and saw that this has been solved.
Since this is already written I will post this anyway.
You can have the delta Symbol and correctly formatted text.
@tcorey is correct; It is a font issue:
The "Delta" Symbol is the letter "D" and is formatted to use the True Type font Symbol.
The remainder of the delta callout uses the "Romans" Style specified on the General tab of the Label Style Composer.
"Romans" uses the Roman.shx font.
This displays as expected.
When I edited the text of one of the label placements, I copied the delta contents to a new line and formatted it all to use the True Type Font Symbol. This replicates your problem display. Check the formatting of the Delta text component.
Christopher Stevens
Message 12 of 17
ChrisRS
You can retain the delta symbol using the capital d character (D) and formatting just that character to use the font "Symbol.ttf."
Christopher Stevens
Message 13 of 17
ChrisRS
Christopher Stevens
Message 14 of 17
Pointdump
Chris,
Thank you. I didn't know you could use different formatting for different parts of a line's content.
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 17
MMcCall402
FWIW, Romans has a delta symbol.  No need for the symbol font just for that.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 16 of 17
ChrisRS
Thanks, @MMcCall402; I was head-slapping myself for disremembering that.  " \U+0394 "
At a certain age, one avoids using terms that include forgetting.
@Pointdump, AutoCAD, and Civil 3D have a lot of obscure elements.
I hope that I am still learning, not just re-learning.
Christopher Stevens
Message 17 of 17
ChrisRS
Hi, @HeathMMGHGS. I had not noticed you were a new participant. Welcome!
I do not know the accepted practice in your region, but I would avoid using "D" as a replacement for the delta symbol. "D" is a common identifier for "degree of curve." You might consider using "CA" for the "central angle."
The other old surveyors in the community may have differing opinions.
Christopher Stevens
