Data referenced pipe network has different style or part list than source drawing in Civil 3D
cyberflow
Advisor Advisor
Message 1 of 13
cyberflow
Hi
I'm trying to figure out why when i create a reference in the host file for a pipe network it always assign "None" for the part list or styles ?
I noticed this article :
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Data-referenced-pi....
But is there anything else that can cause this that someone has experienced ?
Thank you in advance
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Replies (12)
Message 2 of 13
v-silvestre
Hi, I would double check what you have set as defaults within your template by checking the Toolspace > Settings tab > Pipe Network > Edit Feature Settings.  You can set all of the defaults such as structure/pipe styles, parts list, label styles etc.:
Message 3 of 13
MikeEvansUK
I find using the Reference Template works we'll for this.
Link the master drawing into a blank drawing then set the PartsList & labelstyles to be shared before linking the Dref.
The created reference should then retain the styles as per the list.
I'm not a fan of Drefs now (for plan production) since I used them recently, it seems to rebuild all the parts and reset the styles and layers each time for anything which has changed and sometimes which hasn't.
You also cannot seem to redefign the layer setting once a Dref is in the drawing it always defaults back to the very original as set up.
I think especially where styles have been swapped out (from the Default in partslist) for a different style, the Dref should (if the style exists in the drawing) retain the masters style.
It would also be very helpful if the Dref could (as a switch) maintain the masters layering.
I often create a network and subdivide pipes and chambers to different layers for plotting and have had to keep changing the layers of the Dref'd pipework accordingly.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 4 of 13
brian.strandberg
Keep in mind when you data reference something you are getting the data not the styles.  With a pipe network, the parts list controls the association between Structure Name and Style.  Usually I recommend using the same style in your drawing you used when creating the pipe network, then you get the same appearance.
You mention having to do several things to the layers during production, a well designed part list can help make that easier for you.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 5 of 13
cyberflow
Il'l do some testing in the next weeks - I've got to update the source drawings noticed they're made with the old templates so going to update everything and make sur things are synced properly before screaming it's not working.
Will keep you posted for sure with the conclusion/solution if any !
Frank Freitas
LinkedIn
Message 6 of 13
brian.strandberg
Sure you know but just in case.  Make sure if you use the import styles and settings command from the manage tab, to check the 'import settings' box.  There is so much stored in the settings including the critical part list definitions.
I just had an issue with parts in a part list stopped working.  I created a new part list which showed somehow my part list had an issue.  I replaced the concrete pipes (which were having the issue), and recreated that portion of the part list.
This type of thing seems to happen enough that we have a help doc in our system to fix the 'parts list glitch'
Message 7 of 13
cyberflow
@v-silvestre @MikeEvansUK @brian.strandberg
So we've tryed doing the template reference and that didn't work.
I really think there's nothing we can do that i can set already by default what's in the source file unfortunatly ...
And going through the Edit parameters of the Network doesn't give any method to select the differents part list from the master file. It only gives one static choice.
Frank Freitas
LinkedIn
Message 8 of 13
cyberflow
I feel like it's something that has been discussed on the forum without any solution :
https://forums.autodesk.com/t5/civil-3d-forum/data-shortcut-changes-styles-of-pipe-network/td-p/6535...
Frank Freitas
LinkedIn
Message 9 of 13
cyberflow
And here :
https://forums.augi.com/showthread.php?143498-Pipe-Network-Data-Reference-not-keeping-Styles
Frank Freitas
LinkedIn
Message 10 of 13
cyberflow
https://forums.autodesk.com/t5/civil-3d-forum/parts-list-not-coming-up/td-p/12327865
We're all using 2023 in production so this isn't applicable to our situation
Frank Freitas
LinkedIn
Message 11 of 13
cyberflow
Bump
We've noticed that creating a reference of a network and associating it with the same part list doesn't bring the correct parts from the source to the referenced file
The thing is we're using 2 identifical templates but one's a copy of the other one
The source one has different visual differences compared to the one used for drafting production (Showing 1 line for drafting for pipes VS showing external outter lines of pipes)
Is it possible that maybe the drafting template has the same part list but with not the same GUID of each part list maybe ?
Still trying to figure out why things don't get associated correctly when referencing
Frank Freitas
LinkedIn
Message 12 of 13
cyberflow
Update :
I've just tried doing it with the original template that comes with C3D and it does work.
Try to find out what makes it not work when changing template ...
Frank Freitas
LinkedIn
Message 13 of 13
cyberflow
Anyone has a clue why the part list doesn't follow in a drawing when referencing a gravitary network ?
#Help
Frank Freitas
LinkedIn
