I have cross sections generated from a corridor. The engineer has requested cut and fill to be broken up by a range of stations. I have a total cut and fill number generated from comparing the existing and corridor surfaces but my per section tables are blank. I am using Civil 3D 2014. Suggestions?
It seems you are using two different methods for vol calcs and only one is setup properly.
The lower chart is from the Volume Dashboard which reports the results of a TIN volume surface.
The tables you appear to be using look like they are from the section views. They are more than likely set up to work with corridor materials and not the TIN volume surface.
If the FG is from a corridor you should look into using materials to calc cut/fill.
John Mayo
I understand that something is not set up properly. I have tried to apply materials to the corridor but clearly have not completed the process or I'm asking for the info wrong or something. I have been trying to learn what I need to do to get it set up for 3 days and have not been successful. I'm at a loss as to what else to try and that is why I'm asking for help.
