Civil 3D Forum
Curved polyline in 3D 2.5 precent
7 REPLIES 7
Message 1 of 8
edvin_simic
491 Views, 7 Replies
Hello everyone,
I would like to draw a sloped line 2.5 % from the point 200 m until the line reach 4500m (its a flight path for aircraft going around in the missed approach ) How i can do it in most conveniet way in 3D. Thank you very much
Tags (1)
Labels (1)
7 REPLIES 7
Message 2 of 8
pendean
in reply to: edvin_simic
Are you just using "2D" POLYLINE command?
Message 3 of 8
edvin_simic
in reply to: pendean
Im using 3d modeling civil 3D , how could i draw this. Thank you
Message 4 of 8
Valentin-WSP
@edvin_simic ,
You will need to adjust the UCS (Command) and use lines, polylines, or 3D Polylines.
Sample:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
Message 5 of 8
devitg
@edvin_simic  as far as I know , 3dpoly do not hold true arcs, only lines . Please upload your sample .dwg
Message 6 of 8
cwr001
Maybe I'm understanding this wrong but couldn't you just convert your linework to a featureline and use the elevation-table to play around with slopes? You'll get a good grasp of the stationing/elevations.
Message 7 of 8
edvin_simic
THANK YOU GUYS, IT REALLY HELPED. I HAVE ONE MORE LITTLE PROBLEM, I MADE A SLOPED LINE AND WHEN I EXPORT IT IN GOOGLE EARTH IS NOT STRAITH. IN CIVIL3D IS OK
Message 8 of 8
cwr001
I think it's your export settings.
Try setting elevation to "Relative to sea level" and leave elevation at 0.00 (so it will the take the elevation of the object).
Rail Community
