Hi there,
I have created a CSV. file from data that i have recieved from a land survey. I am looking to create a contour file inside of autocad architecture, however, after recent discovery, i have learnt that the program does not have this capability.
I have created the topo surface inside of Revit however, i wish to make a comparison between the topography surface created from the CSV file, and the surface created from a countour file imported from a DWG. Unfortunately, i do not have the capabiltiy to create this DWG. I was wondering if anyone would have the time to generate this file for me? This is a research project for univeristy and unfortunately do not have the access for CIVIL 3D.
I have attached the DWG file of the point data, if anyone could help out would be very well recieved and happy to return the favour in any Revit/Autocad related circumstance 🙂
Muchas Gracias,
Reece.
Solved by Dexterel. Go to Solution.
