Crash, a weird one...
igi_pop
Advisor Advisor
igi_pop
Well, it's a grading thing, so it might not come as a surprise, but I'll share it anyway..
So, I was doing an excavation site, not too deep, not too big. My end-game process for getting what i need included:
  • 2 surfaces with a desired delta (just a lowered duplicate)
  • 2 grading grup, for each vertical phase
  • feature lines describing the bottom
The process - get to a certain level (duplicate lower surface), copy the features to the next site/group, grade them to daylight EG.
All went well, my plan worked, even showed it to the kid and HE LIKED it 😄
Then, for no apparent reason, C3D crashed, again. But hey, I'm Mr. Save-A-Lot, whatever.
BUt when I wanted to open up the drawing again, it just doesn't.
I have 128GB of RAM, and it eats it up within a minute, and does not open. And we're talking about a DWG that's a total of <10MB in size, end DWG was like 3.5MB.
So, I was forced to repeat it all, but with baby steps, saving, auditing, saving, auditing...
And there it was, a HALT mid save.
Ok, repeat from last save - audit - freeze.
And yes, it freezes on save or audit, after i do the COPY FL TO ANOTHER SITE.
Solution?
Copy the FL(s), explode them, and recreate them. And all is well.
For the life of me - I can't figure out why. Cause when i re-did them, i removed no points or whatever to make them different. It just works.
Maybe this helps someone, sometime....
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
Cadguru42
How are you copying the grading/feature lines objects? There has almost always been issues in C3D with using the ACAD COPY command on C3D objects. I remember early on it was considered best practice to NEVER copy a C3D object unless it has its own copy feature. I'm sure it has something to do with that.
C3D 2024-2026
Windows 11
32GB RAM
igi_pop
Hey,
nah, I used the appropriate procedure - select, copy to site. I know grading are fidgety about details, so I take great precaution 🙂
In the end, the copying itself didn't crash a thing, nor subsequential grading. It was the save, and the audit, AFTER I've copied them and done whatever i did later.
So, there's something for sure, but I'm no programmer, so i managed with explode after "copy to site", and recreate the FL in the new site.
navya_gelli
Hi @igi_pop ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
Navya | Community Manager
