Corridor Surface Break
I need to make the road surface of the attached file stop at the beginning of the bridge and begin again at the end. As of now, AC is calculating cut and fill values for the bridge which i DONT want.
Please help!
Thanks!
tcorey
Add to the corridor surface a hide boundary in the area around the bridge.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
That wouldnt effect the cut and fill calcs would it? I tried it and it did hide the surface, but the cut and fill info was teh same
tcorey
Assuming you're using a surface to surface volume calcuation, then, yes, this would affect your volumes. No volumes would be calculated inside the hide boundary.
Tim Corey
Redding, CA
Works! THANKS!
