Civil 3D Forum
Coordinates Transformation Tool 2023
13 REPLIES 13
Message 1 of 14
g.murtaza
806 Views, 13 Replies
Dear All,
I am using (Coordinates Transformation Tool 2023) but when I start to execute the software unexpectedly closed.
can someone help me in this regard?
13 REPLIES 13
Message 2 of 14
Pointdump
in reply to: g.murtaza
Hi Ghulam,
Did you get a dialogue box error? Screenshot please.
Can you post your drawing for testing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 14
g.murtaza
in reply to: Pointdump
Screenshot (443).pngScreenshot (444).pngScreenshot (445).pngScreenshot (446).png
Message 4 of 14
g.murtaza
dwg
Message 5 of 14
g.murtaza
Dear Dave Stoll,
I send you dwg. and screenshots as requested, thanks in advance.
Message 6 of 14
g.murtaza
dwg
Tags (1)
Message 7 of 14
Pointdump
Ghulam,
I see the screen shots, but no drawing was attached.
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 14
g.murtaza
dwg
Tags (1)
Message 9 of 14
g.murtaza
dwg
Message 10 of 14
g.murtaza
I attached dwg. but I don't know why it's not posted.
Message 11 of 14
Pointdump
Ghulam,
Thanks for posting your drawing. After a RECOVER, with a record 155120 Errors, I assigned QND95b/QatarNational Coordinate System. Here's the results of using the Transformation Tool.
I'm using Civil 3D 2022, so I'm not sure if there's a problem with 2023.
Dave
Edit: UTM84-1N won't work because it ends up WAAAAAAY outside of the limits of that coordinate system. Try UTM84-39N instead.
Dave Stoll
Las Vegas, Nevada
Message 12 of 14
Pointdump
Ghulam,
Here's steps I used that work:
Step 1: Use MAPCSASSIGN to assign QND95b.QatarNational to your drawing.
Step 2: Save drawing
Step 3: Use Transformation Tool to transform to UTM84-39N.
Step 4: Use GEOREMOVE to remove assigned coordinate system.
Step 5: Use MAPCSASSIGN to assign UTM84-39N.
Then things work as expected.
Dave
Edit: The Transformation Tool does not transform the Block and MText Objects. Using Map Tools Attach/Query does but it shifts their location.
Dave Stoll
Las Vegas, Nevada
Message 13 of 14
g.murtaza
Dear Dave,
first of all thanks for your response, secondly, I am using civil 3d 2023 I follow all your above steps but on the Third step software closed unexpectedly, I mean same issue. Before I was using version 2022 in that version this tool was working but in version 2023 it is not working.
Message 14 of 14
Pointdump
Ghulam,
Looks like it's time to start a support ticket with Autodesk. Post back if you get a fix from them.
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
