Coordinates Transformation Tool 2023
g.murtaza
g.murtaza
Dear All,
I am using (Coordinates Transformation Tool 2023) but when I start to execute the software unexpectedly closed.
can someone help me in this regard?
Replies (13)
Pointdump
Hi Ghulam,
Did you get a dialogue box error? Screenshot please.
Can you post your drawing for testing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
g.murtaza
Screenshot (443).pngScreenshot (444).pngScreenshot (445).pngScreenshot (446).png
g.murtaza
dwg
g.murtaza
Dear Dave Stoll,
I send you dwg. and screenshots as requested, thanks in advance.
g.murtaza
dwg
Pointdump
Ghulam,
I see the screen shots, but no drawing was attached.
Dave
Dave Stoll
Las Vegas, Nevada
g.murtaza
dwg
g.murtaza
dwg
g.murtaza
I attached dwg. but I don't know why it's not posted.
Pointdump
Ghulam,
Thanks for posting your drawing. After a RECOVER, with a record 155120 Errors, I assigned QND95b/QatarNational Coordinate System. Here's the results of using the Transformation Tool.
I'm using Civil 3D 2022, so I'm not sure if there's a problem with 2023.
Dave
Edit: UTM84-1N won't work because it ends up WAAAAAAY outside of the limits of that coordinate system. Try UTM84-39N instead.
Dave Stoll
Las Vegas, Nevada
Pointdump
Ghulam,
Here's steps I used that work:
Step 1: Use MAPCSASSIGN to assign QND95b.QatarNational to your drawing.
Step 2: Save drawing
Step 3: Use Transformation Tool to transform to UTM84-39N.
Step 4: Use GEOREMOVE to remove assigned coordinate system.
Step 5: Use MAPCSASSIGN to assign UTM84-39N.
Then things work as expected.
Dave
Edit: The Transformation Tool does not transform the Block and MText Objects. Using Map Tools Attach/Query does but it shifts their location.
Dave Stoll
Las Vegas, Nevada
g.murtaza
Dear Dave,
first of all thanks for your response, secondly, I am using civil 3d 2023 I follow all your above steps but on the Third step software closed unexpectedly, I mean same issue. Before I was using version 2022 in that version this tool was working but in version 2023 it is not working.
Pointdump
Ghulam,
Looks like it's time to start a support ticket with Autodesk. Post back if you get a fix from them.
Dave
Dave Stoll
Las Vegas, Nevada
