Civil 3D Forum
Convert surface to UTM coordinates
9 REPLIES 9
Message 1 of 10
pschan13
494 Views, 9 Replies
I have a surface (from .tif file) that is currently in 10TM CRS and I need to convert it to UTM, can I do this in Civil 3d, or do I need to do it outside and bring that file into the surface?
Labels (1)
9 REPLIES 9
Message 2 of 10
Pointdump
in reply to: pschan13
Hi Phil,
You can use the >>>Coordinate Transformation Tool<<< or start a new drawing in UTM and bring in the original Tiff file.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 10
pschan13
Sorry, I forgot to mention I'm using Civil3D 2018, is the coordinate transformation tool available in 2018?
Message 4 of 10
Pointdump
Phil,
Sadly, the Coordinate Transformation Tool wasn't introduced until 2023. Maybe time for an update?
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 10
paulo_santoso
Try MAPCSASSIGN from Planning and Analysis ribbon
Paulo Santos | BIM Expert | LinkedIn | Contatos |
Message 6 of 10
lim.wendy
Hi Phil,
Thanks for posting and welcome to the Civil 3D forum. In addition to the suggestions above by Dave and Paulo, take a look at this thread on how to convert a drawing to UTM coordinates.
I hope that helps; let us know if you need further assistance.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Customer Value Hub
Message 7 of 10
pschan13
Thanks for the suggestions. I am unable to do this within Civil 3D, and I have used ArcMap to complete the conversion.
Message 8 of 10
Pointdump
Phil,
ArcMap will transform a Civil 3D Surface?
Dave
Dave Stoll
Las Vegas, Nevada
Message 9 of 10
pschan13
in reply to: Pointdump
Not directly, the surface was created from a geotif, so the underlying data is in a format which arcmap can convert
Message 10 of 10
Pointdump
Phil,
Civil 3D can transform a geotiff to whatever coordinate system you're using in your drawing. You don't need to go to ArcMap for that.
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
