Civil 3D Forum
contours around curves
7 REPLIES 7
Message 1 of 8
wbrustle
1844 Views, 7 Replies
wbrustle
I was wondering if anyone knows of a way to evenly space contours around a curve in a surface.
Many times I have a steep area in a surface that needs to be displayed using 1 foot contour intervals, and in certain areas the contours are crossing each other around curved areas, like a curve in a ditch. Is there a way or a setting I am missing that may help to alleviate this problem. In the past i have had to "fudge" the surface a little to get the contours to look correct.
7 REPLIES 7
Message 2 of 8
neilyj666
in reply to: wbrustle
neilyj666
Do you have any sort of smoothing applied to these contours?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2025 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 8
wbrustle
in reply to: neilyj666
wbrustle
yes, I have it set to the maximum it can be
Message 4 of 8
BrianHailey
BrianHailey
Contours should never cross each other in a TIN surface. If you smooth the contours, you are sacrificing the accuracy of the contours so they "look pretty". Instead of smoothing the contours, try smoothing the surface.
I wrote about it on my blog HERE.
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
GEI Consultants
My Civil 3D Blog
Message 5 of 8
wbrustle
in reply to: BrianHailey
wbrustle
thank you so much. Our company moved from LDD 2008 right to Civil 3d 2013 with no training....is smoothing a surface new or was it always available? I didn't even know there was a command for that. I had always just smoothed contours. I can't wait to try this!!!! These discussion groups have been a tremendous help. I usually get a reply to a posted question within minutes and most of my questions are answered so thanks again to all the experts.....we all know how frustrating it is when something does not work the way its suppose to 🙂
Message 6 of 8
wbrustle
wbrustle
one more question about smoothing suface...............what point interpolation/exreapolation output location is recommended?
Message 7 of 8
Neilw_05
Neilw_05
I usually go by trial and error. Try a setting and see if it gives satisfactory results. Assign an area that encompases the problem and apply. You DON'T want to smooth the whole site as smoothing adds processing time.
If you are only concerned about the pretty picture and don't need a precise surface in that area, try bumping down your contour smoothing to half. Using full contour smoothing almost always results in crossing contours.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
WIN 10 64 PRO
Message 8 of 8
wbrustle
in reply to: Neilw_05
wbrustle
ok...I will try that....thank you!
Rail Community
