I was wondering if anyone knows of a way to evenly space contours around a curve in a surface.
Many times I have a steep area in a surface that needs to be displayed using 1 foot contour intervals, and in certain areas the contours are crossing each other around curved areas, like a curve in a ditch. Is there a way or a setting I am missing that may help to alleviate this problem. In the past i have had to "fudge" the surface a little to get the contours to look correct.
Link copied
