Civil 3D Forum
Getting 2013's linetype set into 2012??
3 REPLIES 3
GreeneSWCD
298 Views, 3 Replies
2013 has a linetype called "proposed tile" and another one called "existing tile."  2012 doesn't have either.  Is there any way I can could get those two files so I could load those two linetypes into 2012?
Thanks.
3 REPLIES 3
in reply to: GreeneSWCD
Out of Curiosity Are the simple linetypes, or complex linetypes?
You might be able to draw both linetypes into an empty drawing. use the "-EXPORTTOAUTOCAD" to save the file back to a 2010 format, then use design center "CTRL+2" to import the linetype from an open drawing.
If you would like more details on those steps, let me know.
rkmcswain
Use TO-LIN.LSP to extract the definition to a file.
 TO-LIN.LSP can be found here: http://www.turvill.com/t2/free_stuff/index.htm
R.K. McSwain     | CADpanacea | on twitter
GreeneSWCD
in reply to: rkmcswain
Ok, I'll be back in the office that has 2013 tomorrow, Tuesday.  So I'll investigate both of the listed options then.  Thanks guys!
Rail Community
