- Mute
- Permalink
- Report
Hi
I'm trying to setup Captivate and Civil3d to work together with lineworks.
The problem i seem to have is that Leica runs a Start - Continue system and Civil3d is a Start - Continue - Stop system.
This is what my endings look like:
1003 BE
1003 FO
1002 BE
1002 FO
6000 --
6000 --
1002 BE
1002 FO
1002 --
1003 --
1002 is the code and BE/FO the linework.
The -- means theres no linework and it should not be part of any lines
What happens is that the 1002 BE will connect with the 1002 FO as intended, but then it'll continue down connecting all the 1002 -- aswell.
Now since i'm running Captivate, i use the build in Lineworks, wich only has a Begin and a Continue, choosen via GUI.
I imagine the problem is that i have no End, but that does not seem to be an option for Captivate and i'm guessing there's a way around it.
I've disabled the Automatically begin linework on prefix match option, but that did not fix the issue.
Basically i'd like Civil3d to only process linework if there's a linework code
Any help would be much appreciated!
Kind regards Mikkel
