Sample offset profile incorrect
Message 1 of 15
Sample offset profile is incorrect. What causes this strange behaviour?
Replies (14)
Message 2 of 15
ilia.borisov
Sackgasse - DGM - (1) (1) is it existing ground or created by corridor links, if it existing then maybe is incorrect and you would to lower manually surface points in that area, if its corridor surface the assembly (that most probably is custom created by SAC and i cant see it ) has a target that make it bump like that
Message 3 of 15
Surface "Sackgasse - DGM - (1) (1)" is existing and shows correctly in plan view and 3D view. Only in profile view it is incorrect
Message 4 of 15
ilia.borisov
Then like I said you will need to turn on points of surface and lower them manually.
Message 5 of 15
I do not understand. The surface is correct. Why should I lower points of a correct surface? Why the sample offset profile is not correct?
Message 6 of 15
ilia.borisov
The sample profile only show you how surface look like at that specific place, the problem is not with the profile but with the surface.
Message 7 of 15
ilia.borisov
Ok my mistake I misunderstood you, the problem is that you have wrong surface on profile view, it has to be Surface "Sackgasse - DGM - (1) (1)" but its not.
Message 8 of 15
Message 9 of 15
ilia.borisov
Try that Create Profile from surface and add Sackgasse - DGM - (1) (1) and you will see the diference
Message 10 of 15
I appreciate your help but you do not understand the problem
Message 11 of 15
ilia.borisov
I think You want this result
Message 12 of 15
Yes! Including elevation labels in the profile band
Message 13 of 15
ilia.borisov
Ok i just change surface in profile view like i said before but you will have to move alignment a little bit because now is on the edge and wont show desired result but the problem is the surface is not on profile view or atleast not that surface that is shown in 3d view
Message 14 of 15
Thanks but this is not the solution
Message 15 of 15
ilia.borisov
Your alignment just dont lay over that part of the surface that is shown on the 3dview
