Text component editor is grayed out .. Student version .. I can't edit text .. it suppose to be like pic 2 "attached" .. any help to activate it plz ?
1. Select Labels on your alignment.
2. Edit alignment labels.
3. At the top of this dialog, select the Type and the style. In the drop down to the right "edit current selection".
4. Go to LAYOUT tab.
5. Select contents.
You should be able to get it from here.
_______________________________________________________
OR
1. Settings tab in Toolspace
2. Alignment
3. Label Styles
4. Station
5. Major Station (as one example)
6. Parallel with Tick (as one example)
7. Edit
Bill
If items like that are greyed out you have locks set somewhere in the hierarchy of your template, either in drawing setting or labels somewhere.
Rick Jackson
Survey CAD Technician VI
I'm having the same issue with the full version of Civil3d 2020 after upgrading Windows to Windows 10. Windows 7 did not have this issue.
I've tried editing text in general labels, alignment labels and surface labels with the same result.
I just tried changing the text style that I use to a Tru Type font and the editor is working!
Full uninstall then reinstall yesterday afternoon fixed the problem. Tried repair but repair wouldn't run so I'm guessing a bad install.
