civil 3D 2020
civil 3D 2020
Text component editor is grayed out .. Student version .. I can't edit text .. it suppose to be like pic 2 "attached" .. any help to activate it plz ?pic1-issuepic1-issuepic2 -it suppose to be like thispic2 -it suppose to be like this
Replies (7)
wfberry
1. Select Labels on your alignment.
2.  Edit alignment labels.
3.  At the top of this dialog, select the Type and the style.  In the drop down to the right "edit current selection".
4. Go to LAYOUT tab.
5. Select contents.
You should be able to get it from here.
_______________________________________________________
OR
1.  Settings tab in Toolspace
2. Alignment
3. Label Styles
4. Station
5. Major Station (as one example)
6. Parallel with Tick (as one example)
7. Edit
Bill
First of all , Thanks for your reply
but that is not what i meant
it wasn't about changing text color or size .. but about editing the text
FORMULA "add or remove text" as shown in the attached screenshots
rl_jackson
If items like that are greyed out you have locks set somewhere in the hierarchy of your template, either in drawing setting or labels somewhere.
Rick Jackson
Survey CAD Technician VI
wfberry
Your second pic shows wanting to change the Font.  That is what I related.
Bill
I'm having the same issue with the full version of Civil3d 2020 after upgrading Windows to Windows 10. Windows 7 did not have this issue.
I've tried editing text in general labels, alignment labels and surface labels with the same result.
I just tried changing the text style that I use to a Tru Type font and the editor is working!
pendean
Community Legend
Community Legend
>>>..Civil3d 2020 after upgrading Windows to Windows 10...<<<
You most likely need to remove and reinstall C3D 2020, most do.
Full uninstall then reinstall yesterday afternoon fixed the problem. Tried repair but repair wouldn't run so I'm guessing a bad install.
