Civil 3D Forum
Cannot modify or delete superelevation
2 REPLIES 2
jfengineering
936 Views, 2 Replies
I have run into a problem trying to delete or modify a superelevation.  I manually created the superelevation by selecting the alignment, then clicking on the "+" symbol in the tabular editor.  I repeated the "+" to get the Transition In / Out regions.  (This is on a tangent approaching an intersection.)  I was not able to get the tabular editor to display the typical Runout / Runoff sections.  I tried to delete the stations and the entire superelevation with no luck.  I even tried undoing to a point prior to creating the super.  Now I can not make any edits to the information, nor can I create new superelevation data.
Running an Audit command returns no errors found/fixed, but does pop an error box that says "One or more associative objects cannot be resolved."  (See attached).
I thought I was going to be getting plans out the door today, but not anymore. Smiley Frustrated
JF Engineering, PLLC
Civil3D, Current/Win 10 Pro
MSI MPG X570/AMD Ryzen 5 3.6 GHz
EVGA GTX 1650, 4GB
1TB Samsung 970 M.2
16 GB DDR4 3200MHz RAM
2x ViewSonic VX2458 24in Monitors
2 REPLIES 2
Jay_B
in reply to: jfengineering
As for the error you're seeing, are any layers locked?
See this related AKN article
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
I had the same problem, Audit did not help but Recover solved the problem.
Technical Services Manager
Devotech Group of Companies
Devotech iDAS (Infrastructure Design Automation Suite)
Rail Community
