I have run into a problem trying to delete or modify a superelevation. I manually created the superelevation by selecting the alignment, then clicking on the "+" symbol in the tabular editor. I repeated the "+" to get the Transition In / Out regions. (This is on a tangent approaching an intersection.) I was not able to get the tabular editor to display the typical Runout / Runoff sections. I tried to delete the stations and the entire superelevation with no luck. I even tried undoing to a point prior to creating the super. Now I can not make any edits to the information, nor can I create new superelevation data.
Running an Audit command returns no errors found/fixed, but does pop an error box that says "One or more associative objects cannot be resolved." (See attached).
I thought I was going to be getting plans out the door today, but not anymore.
As for the error you're seeing, are any layers locked?
I had the same problem, Audit did not help but Recover solved the problem.
