Civil 3D Forum
C3D 2016 - Extract Solid from Surface Command
2 REPLIES 2
MarySeufert
867 Views, 2 Replies
Can anyone with a clean OOTB installation verify if the command shows up as described in this post:
https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/CloudHelp/cloudhelp/2016/...
My installation at work does not have it, and I need to confirm before a meeting whether or not I need to get annoyed with IT.
Thanks all!
EXPERT ELITE MEMBER
2 REPLIES 2
tcorey
in reply to: MarySeufert
You didn't mention your version. This is a fairly new tool, introduced in Civil 3D 2016 or so.
If it's not on your menu, try typing ExportSurfacetoSolid.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
MarySeufert
in reply to: tcorey
Meeting happened and I brought up that all of our ribbon contents are not there.  The explanation with my editorializing...They were lazy and utilized probably a 2013 deployment package... So ribbon contents are missing, but as you suggested, the command works.
Version is in Subject line Smiley Wink
EXPERT ELITE MEMBER
Rail Community
