I've created an infraworks model, then imported into Civil 3D. I've pulled up bing maps into civil 3D, and the alignment is terrerfic. Using State Plane NAD83 IVF.
I have a survey. Pulled in Bing Maps into Civil 3D. Using State Plan NAD 83 IVF. I translate the survey onto the bing map.
Then I xref the survey into the first drawing, and I have a translation issue of 16607.40 feet away. I cannot figure out why xrefing the topo into the first drawing does not insert in the correct location. Any Idea what is going on?
Solved by Pointdump. Go to Solution.
Solved by rl_jackson. Go to Solution.
Hi Mike,
"I translate the survey onto the bing map."
You lost me there. What did you do?
Dave
Dave Stoll
Las Vegas, Nevada
Could you mean your xrefing the file into your drawing, and its not matching....
I'd first check the INSUNITS and verify that both files are set to unitless for insertion. That can really send things for a whirl.
Rick Jackson
Survey CAD Technician VI
Yep. Units are set to feet in the survey file. Change to unitless and all should be good.
Rick Jackson
OK you need to do 2 things.
Type Base in the survey - this should be 0 (Also where the 16k is coming from)
Type Units and set everything to Unitless in both files for the insertion.
Fix files attached.
Rick Jackson
Good catch Rick.
Dave Stoll
Las Vegas, Nevada
Thank you. It's been 20 years since I used that command. Appreciate the reminder.
