Civil 3D Forum
Bing Maps, Infraworks, Transformation issues
6 REPLIES 6
mikeshick
412 Views, 6 Replies
I've created an infraworks model, then imported into Civil 3D.  I've pulled up bing maps into civil 3D, and the alignment is terrerfic.  Using State Plane NAD83 IVF.
I have a survey.  Pulled in Bing Maps into Civil 3D.  Using State Plan NAD 83 IVF.  I translate the survey onto the bing map.
Then I xref the survey into the first drawing, and I have a translation issue of 16607.40 feet away.  I cannot figure out why xrefing the topo into the first drawing does not insert in the correct location.  Any Idea what is going on?
Mike Shick
www.medesigns.us
6 REPLIES 6
Pointdump
in reply to: mikeshick
Hi Mike,
"I translate the survey onto the bing map."
You lost me there. What did you do?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
rl_jackson
Could you mean your xrefing the file into your drawing, and its not matching....
I'd first check the INSUNITS and verify that both files are set to unitless for insertion. That can really send things for a whirl.
Rick Jackson
Survey CAD Technician VI
rl_jackson
Yep. Units are set to feet in the survey file. Change to unitless and all should be good.
Rick Jackson
rl_jackson
OK you need to do 2 things.
Type Base in the survey - this should be 0 (Also where the 16k is coming from)
Type Units and set everything to Unitless in both files for the insertion.
Fix files attached.
Rick Jackson
Pointdump
in reply to: rl_jackson
Good catch Rick.
Dave Stoll
Las Vegas, Nevada
mikeshick
in reply to: Pointdump
Thank you.  It's been 20 years since I used that command.  Appreciate the reminder.
Mike Shick
www.medesigns.us
Rail Community
