- Mute
- Permalink
- Report
I am trying to apply a block along a polyline between 2 points.
I have used the ARRAYPATH command which works great along an entire line, however, I would like to just apply it between two points on this line.
Ideal automation:
I click a start and end point along a polyline and my block is automatically inserted similar to the ARRAYPATH command (fills entire line, aligns blocks tangent to polyline, etc.)
Is there a way to make a block like this? I experimented with trying to create a linetype which would repeat a block but this did not work. I need something easy to automate since I need to apply it sporadically over several miles of polyline.
See the attached screenshot and let me know if I can give any more information which will help to answer this question.
Thank you for your help!
