Corridor Section Editor View is Gone
Message 1 of 20
My section view is not showing up when I try to open the Section Editor for my corridor. How can I get it back?
Replies (19)
Message 2 of 20
doni49
While you have the Section Editor open:
  1. Section Editor tab > View Tools panel > Viewport Controls.
  2. Set the "Layout" (on the left) to show the appropriate number of views.
  3. Set the Viewports (on the right) assigning each VP as desired.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 3 of 20
I have tried changing the viewport configuration in the section editor and it does not help
Message 4 of 20
Here is a screenshot of my viewport configuration
Message 5 of 20
doni49
Try changing the viewport configuration to show only the PLAN VIEW.  Then change it back to showing both.  This SHOULD re-initialize the VP settings.
If that doesn't work, change the config to only the Plan view and CLOSE the section editor.  Now re-open the section editor and change the VP configu back to showing the section view.
Don Ireland
Message 6 of 20
When I try changing the viewport configuration to only show the plan view I receive an error message that says one viewport must be set to Section view.  Here is a screenshot of the error message.
Message 7 of 20
doni49
Have you tried closing and restarting the Section Editor yet as previously suggested?
Don Ireland
Message 8 of 20
Yes I have closed out of the Section Editor and when I reopen it the view is still messed up.  I have even closed the drawing and reopened it but to no avail
Message 9 of 20
MikeEvansUK
I assume that this is not just at a single corridor section but displays like this in all?
I would try sectioning the corridor, do the sections display correctly? If not you may have a rogue target or assembly spiking to infinity..
Other ideas.
Turn off any Hardware acceleration.
Audit the file, sometimes we get problems with stuff (Duplicate ID's etc) on the Fly - Seeing this more and more in R2016.
please turn all layers on and thaw all layers. (doubt if that will help but something may be wrong).
Adjust the start point of the corridor a bit then re-build it.
Check your UCS settings maybe for some reason the corridor is not correctly aligned to WORLD.. - UCS, Plan.
Otherwise, it could just be a corrupt file. Try inserting it into a fresh template to see if this Fixes it.
M
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 10 of 20
doni49
Following is a screenshot taken from Section Editor on my PC.  Compare this to the OP's screenshot.  See the difference between the nav wheels?  It appears that the Section Editor is actually turning the VP iternally for the purposes of showing the sections.  But OP's VP is not doing this.
Edit:  I was also unable to reproduce having the VP not show the grid lines by turning layers off.
Don Ireland
Message 11 of 20
I believe my file has been corrupted.  I created a data shortcut for the corridor and created a reference of it in a new drawing and the section editor works perfectly fine.  Is there a way to promote the corridor into this new drawing? When I try to promote it from the data shortcuts the "promote" button is greyed out.
Message 12 of 20
doni49
The more we've dug into this issue, the more I've come to think the same thing.  Have you tried running the Audit command on the original file?  How about RECOVER?
Don Ireland
Message 13 of 20
Ran Audit and there were 114 errors but after it fixed them the Section Editor view is still messed up
Message 14 of 20
doni49
Now that you've run the Audit command, try closing the Section Editor and re-opening it again.  And in fact, I think I would:
  1. Close Section Editor.
  2. Run the Audit command (and let it fix errors).
  3. Save the dwg file.
  4. Close the dwg file.
  5. Re-open the dwg file.
  6. Run the Audit command (without FIX enabled) just to confirm there are no more errors.
  7. If no errors found, Re-open the Section Editor.  If it did find errors, go back to step 2 and repeat until there are no errors found.
Don Ireland
Message 15 of 20
Did all these steps until no errors were found when running Audit and the Section Editor view still does not work
Message 16 of 20
doni49
Post a copy of your audited/fixed file and someone should be able to investigate more.
Don Ireland
Message 17 of 20
doni49
ALSO:  what version (including SP#) are you using?
Don Ireland
Message 18 of 20
j_schroeder1
Just want to ensure due diligence and give my 2 cents. I had the same issue occuring. The problem was a subassembly link targeting a profile and alignment. It couldn't find the profile and was targeting to zero. So my section view grid in section editor was displaying elevations in the 450' ballpark instead of 900'. This seems like an obvious no-brainer, but it was giving me fits so I figured I would share just in case.
Message 19 of 20
DArmstrongDOT
We had a C3D 2020.6 user who also experienced a blank Corridor Section Editor, CSE, viewport. After a couple hours of troubleshooting, I noticed that the current Layer was locked.  Once unlocked and the CSE reopened, all was well again.
Another Current Layer related issue is the CSE grid displaying with an odd linetype.  We discovered that the Section Editor grid inherits/uses the linetype assigned to the current AutoCAD layer.  Once the current layer was assigned a continuous linetype, the grid appeared normal.
Message 20 of 20
Ronczez
I had similar Issue.
In my case turnoff all freezeed layers was the solution.
