I assume that this is not just at a single corridor section but displays like this in all?
I would try sectioning the corridor, do the sections display correctly? If not you may have a rogue target or assembly spiking to infinity..
Other ideas.
Turn off any Hardware acceleration.
Audit the file, sometimes we get problems with stuff (Duplicate ID's etc) on the Fly - Seeing this more and more in R2016.
please turn all layers on and thaw all layers. (doubt if that will help but something may be wrong).
Adjust the start point of the corridor a bit then re-build it.
Check your UCS settings maybe for some reason the corridor is not correctly aligned to WORLD.. - UCS, Plan.
Otherwise, it could just be a corrupt file. Try inserting it into a fresh template to see if this Fixes it.
M
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
