this one was asked before but unfortunately never answered. (So I guess, as with many unanswered things, it can't be done.)
Still, is it possible to label the difference between two profiles (not surfaces!) in an alignment station/offset-label?
I want my "Height"-value to show "0.70".
Cheers!
Thanks for the reply - unfortunately they are not at a constant elevation so this kind expression won't suffice.
Next stop dynamo I guess! 🙂
I researched this type of situation in the past, and what I believe I came up with (in theory, and in some testing) is to generate a surface from the profile, either by using feature lines to create a surface, or a corridor with a level section. Just enough to give an actual surface under the alignment. then labeled the difference between the two surfaces. We never actually used it on a real project, as the project manager caboshed the idea of trying to save time by attempting to automate the process.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
