hi. i want elevation differences between profiles to be shown like this picture.
any suggestions?
Solved by MMcCall402. Go to Solution.
You can have the labels placed automatically in a Band style, but they will be at a consistent elevation in each profile view. You can have the labels placed manually and get the positioning you show using a profile view station and elevation label style.
If you have surfaces related to those two profiles you could make a Volume Surface and then add a Reference Text component to the label to get the 'elevation' from that volume surface. The 'elevations' of the volume surface would be the different between the two.
thanks a lot
@MMcCall402wrote:If you have surfaces related to those two profiles you could make a Volume Surface and then add a Reference Text component to the label to get the 'elevation' from that volume surface. The 'elevations' of the volume surface would be the different between the two.
