Civil 3D Forum
Alignment station offset label: profile elevation differences
3 REPLIES 3
cwr001
549 Views, 3 Replies
this one was asked before but unfortunately never answered. (So I guess, as with many unanswered things, it can't be done.)
Still, is it possible to label the difference between two profiles (not surfaces!) in an alignment station/offset-label?
I want my "Height"-value to show "0.70".
Cheers!
3 REPLIES 3
lim.wendy
in reply to: cwr001
Hi @cwr001 ,
Thanks for posting. 🤔
Looks like your 2nd profile is at a constant elevation? If yes, you can create an expression and the add a Reference text to the alignment label. See this screencast:
Otherwise, you will need to create a volume surface as discussed here
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
cwr001
in reply to: lim.wendy
Thanks for the reply - unfortunately they are not at a constant elevation so this kind expression won't suffice.
Next stop dynamo I guess! 🙂
chriscowgill7373
in reply to: cwr001
I researched this type of situation in the past, and what I believe I came up with (in theory, and in some testing) is to  generate a surface from the profile, either by using feature lines to create a surface, or a corridor with a level section.  Just enough to give an actual surface under the alignment. then labeled the difference between the two surfaces.  We never actually used it on a real project, as the project manager caboshed the idea of trying to save time by attempting to automate the process.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Rail Community
