Adding a range to a cut/fill banding surface
civilman1957
civilman1957
Good morning, all...
I've created a cut/fill banding surface in order to see areas of extreme elevation change in our design drawing. Unfortunately, I didn't take my ranges high enough to account for the most fill needed. I only made them to a max if 3 feet of fill, and I need four. Anyone know if I can add a range to my surface without starting over again?
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
Joe-Bouza
go back to the analysis tab and re do with 4 ranges
Joe Bouza
civilman1957
Yep, I know I can do that...I just was hoping I could "append" my ranges and not start all over again....
SteveLDucharme
One of THE most frustrating issues with the use of banding especially when using volume surfaces which change often. It's astounding to me that after about a decade of using this tool there is still no way to save banding styles/ color settings/ranges. I can't imagine it's a major challenge for the developers. We use a LOT of it and I think my hands are now able to almost automatically type in the color schema and increments almost without looking.
civilman1957
I'll go along with that. I don't mind re-doing it, but for whatever reason, my cad runs super slow while assigning range values. I have rebuild off and so on, but it still takes forever...
