Civil 3D Forum
weird text size
2 REPLIES 2
481 Views, 2 Replies
weird text size
i dowloaded autocad civel 3d a couple of weeks ago and i have this problem with the text sizes but i  cant find a solution does anyone else have this problem and maybe nows how to solve it.
here some printscreens
2 REPLIES 2
The font size display in AutoCAD is governed by your screen resolution and the font size setting in the operating system.
AutoCAD itself does not have a setting for this. The closest option would be "Use large buttons for Toolbars" under the Display tab in the Options dialog box.
You can try resolving this problem by doing one of the following:
  • Change the display text size in AutoCAD by reducing your monitor screen resolution.
  • Adjust the font size in Windows. (This choice can cause text to no longer fit correctly in AutoCAD. The UI in AutoCAD is designed for 100% font size and may not scale well.)
To adjust the font size in Windows:
Windows 7 and 8:
  1. Click the Start menu and type "display" in the search field or type it at the desktop.
  2. Click "Set custom text size (DPI)."
  3. Choose a percentage in the drop-down menu or drag the ruler.
  4. Click OK.
ACADuser
Are you running the software on a ultra HD monitor?  There have been reported issues running AutoCad on HiDPI/UHD monitors.  I am not aware if the issue has been resoved but there are quite a few posts relating to this issue.  Here is one which appears to show the same issue as yours > Why AutoCAD 2015 is still not HiDPI compatible​?
ACADuser
Civil 3D 2018, Raster Design 2018
Windows 7 Enterprise
Dell Precision 5810 Workstation
Intel Xeon E5-1630 v3 @ 3.70GHz
32GB RAM, NVIDIA Quadro K2200 4 GB GDDR5
DUAL 27" Dell UltraSharp U2713HM
Rail Community
