Civil 3D Forum
add widening always gives no solution
7 REPLIES 7
Message 1 of 8
wang890
2275 Views, 7 Replies
i am adding widening on an alignment which is only a line. just use the default values it gives no solution. sometimes works when i pick the start and end but pick anywhere in between will never work. super annoying.
Stantec
Dell Precision 5530, Prism M320PU, C3D 14/17/19
7 REPLIES 7
Message 2 of 8
in reply to: wang890
I have the same problem. When I add widening with start station, end station, and width, sometimes it works; sometimes not. My offset alignment is static.
Is there anyone to give me an idea for the alignment widening?
Thank you
Message 3 of 8
andrewpuller3811
I was having this problem and I ended up just doing a small widening, about 30m long in a straight section of the alignment, accepting the default parameters and then editing the parameters once it was created.
If editing the parameters does not work, just drag the grips.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
Message 4 of 8
Cadguru42
What version are you using? Are you using 64-bit or 32-bit?
C3D 2022-2025
Windows 11
32GB RAM
Message 5 of 8
in reply to: Cadguru42
I use Civil 3D 2010 32 bit mode.
Thank you
Message 6 of 8
I was having the same problem so I followed the advice and added a widening farther down. It still kept preventing me from moving it to the station I needed when I noticed the transition point at entry was longer than the available alignment. I changed my entry length parameter to 0 and was able to move the widening. Thanks for putting me on the path.
Message 7 of 8
tcorey
in reply to: davescottmay
I love when someone is able to dig up a link from the past, a twelve-year-old thread, to find a solution today. It gives me a sense of time travel.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 8 of 8
wzerx1
Just check your settings, Commands, Add Widening, Widening Options and adjust as desired
Rail Community
