i am adding widening on an alignment which is only a line. just use the default values it gives no solution. sometimes works when i pick the start and end but pick anywhere in between will never work. super annoying.
Solved by davescottmay. Go to Solution.
I have the same problem. When I add widening with start station, end station, and width, sometimes it works; sometimes not. My offset alignment is static.
Is there anyone to give me an idea for the alignment widening?
Thank you
I was having this problem and I ended up just doing a small widening, about 30m long in a straight section of the alignment, accepting the default parameters and then editing the parameters once it was created.
If editing the parameters does not work, just drag the grips.
I was having the same problem so I followed the advice and added a widening farther down. It still kept preventing me from moving it to the station I needed when I noticed the transition point at entry was longer than the available alignment. I changed my entry length parameter to 0 and was able to move the widening. Thanks for putting me on the path.
I love when someone is able to dig up a link from the past, a twelve-year-old thread, to find a solution today. It gives me a sense of time travel.
