Add Aped Distance and Tangent Length In Curve Label
nirmal.maisuria
nirmal.maisuria
Hello Everyone,
I'm just unable to find length of "appex distance" and "Tangent length" property in "Tangent Intersection Label Style".
I hope , any one of you can help me.
Thank you
Nirmal
Pointdump
Nirmal,
The Apex Distance is also called External Distance, the nearest distance from PI to the curve.
You'll need to create an Expression:
{General Segment Curve Radius}*((1/COS({General Segment Total Angle}/2)-1))
For Tangent Length, use "General Segment Curve External Tangent".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
nirmal.maisuria
Thank you sir for your kind response.
I fix the problem.
Nirmal
DonaldHaas7284
Hi Dave,
I was wondering why I would be getting no answer and just ??? for this formula. I calculated it manually and I am getting a number.
BrianHailey
I just used Dave's expression and it worked. I did it for an alignment so I had to change the properties a bit but it worked just fine. Can you screenshot your expression?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
DonaldHaas7284
Hi Brian,
I was able to figure it out. It had something to do with the style type I was using.
