Nirmal,
The Apex Distance is also called External Distance, the nearest distance from PI to the curve.
You'll need to create an Expression:
{General Segment Curve Radius}*((1/COS({General Segment Total Angle}/2)-1))
For Tangent Length, use "General Segment Curve External Tangent".
Dave
Dave Stoll
Las Vegas, Nevada
I just used Dave's expression and it worked. I did it for an alignment so I had to change the properties a bit but it worked just fine. Can you screenshot your expression?
Hi Brian,
I was able to figure it out. It had something to do with the style type I was using.
