Civil 3D Forum
Add Aped Distance and Tangent Length In Curve Label
5 REPLIES 5
nirmal.maisuria
988 Views, 5 Replies
Hello Everyone,
I'm just unable to find length of "appex distance" and "Tangent length" property in "Tangent Intersection Label Style".
I hope , any one of you can help me.
Thank you
Nirmal
5 REPLIES 5
Pointdump
in reply to: nirmal.maisuria
Nirmal,
The Apex Distance is also called External Distance, the nearest distance from PI to the curve.
You'll need to create an Expression:
{General Segment Curve Radius}*((1/COS({General Segment Total Angle}/2)-1))
For Tangent Length, use "General Segment Curve External Tangent".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
nirmal.maisuria
in reply to: Pointdump
Thank you sir for your kind response.
I fix the problem.
Nirmal
DonaldHaas7284
Hi Dave,
I was wondering why I would be getting no answer and just ??? for this formula. I calculated it manually and I am getting a number.
I just used Dave's expression and it worked. I did it for an alignment so I had to change the properties a bit but it worked just fine. Can you screenshot your expression?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Hi Brian,
I was able to figure it out. It had something to do with the style type I was using.
Rail Community
