Civil 3D Forum
acre feet units
6 REPLIES 6
CADmgrMike
688 Views, 6 Replies
acre feet units
Is there any way in C3D to get a volume calculation in acre feet instead of cubic feet?
Mike Porter
https://provostandpritchard.com/
6 REPLIES 6
rl_jackson
in reply to: CADmgrMike
Use an expression
CF/43560
Rick Jackson
Survey CAD Technician VI
troma
CADmgrMike
in reply to: rl_jackson
I guess to be more precise, where would I put the expression?
I would like to have it in a surface table.
Mike Porter
CADmgrMike
in reply to: troma
Seriously. 🙂
The initial post discussion was what I'm looking for, but the discussion degenerated into a debate on imperial vs metric units.
There was never an answer to the question.
Mike Porter
troma
Yeah that was my fault wasn't it.
Anyway, the conversion factor is there for you, just a matter of where to put it.
Mark Green
Working on Civil 3D in Canada
autoMick
The simple way is just type the conversion factor directly into the volumes dashboard, so instead of cut and fill factors of 1.000 change them to the decimal your're after. So if your dashboard is currently showing cu ft., type in 0.00002296 for the cut and fill factors and check the result.
[edit] if you need more decimals go to the drawing settings. Or if you want to be specific, edit the VolumeDashboard Surface command settings
Cheers
- Mick
Civil3d user in Australia since 2012.
Rail Community
