Civil 3D Forum
3 Sided Earthworks
6 REPLIES 6
william_beaumontGMYRE
283 Views, 6 Replies
3 Sided Earthworks
Hi there,
We are placing a platform into a side of the mountain and it will 3 sides of cut but I am not sure how to show that in Civils 3D?
Any suggestions would be appreciated.
Kind Regards,
Bill
6 REPLIES 6
Hi @william_beaumontGMYRE
First of all you should approach it with the grading tools
Did you?
Hi there,
No I didn't - it is built up with alignments, profiles and corridors. I am not familiar with using grading tools. Is that a better method?
Yes for design regarding buildings the grading tools are better (and more easy and simple that corridor).
I think it worths to spend some time and understand how grading tools are working. You just need proper feature lines and then you can design what ever you want.
Corridor could work with more time and complexity...
Share the concept for the earthworks around your proposed building (slopes+widths) and i can give you recommendations
Fairly simple - require 2 pads at 60x40m which are level @ 800m elevation and a haul road up to them at no more that 1 in 10 gradient
You are done.
add a base line and  assembly connecting the end of you corridor
Joe Bouza
Rail Community
