2017 Geotechnical Module
Hello!
I need help to solve this problem. I don't understand this behavior. My CSV files are correctly filled.
Information: CSV files, showed no problems on another computer with Civil 3D 2015.
https://www.youtube.com/watch?v=3WnVZsnPA5Q
Thanks!
Replies (10)
Pointdump
Felipe,
Post both CSV files. I'll test it in 2017 and see if I get the same.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Hi!
Thanks!
Pointdump
Felipe,
I'm not sure what is going on, but even though it shows the CSV's are "Valid", it's not importing them.
Dave
Dave Stoll
Las Vegas, Nevada
First: thank you for your attention.
You did the same as I did, as the video. Right?
I do not understand the "4 warnings" in your test.
You could send me CSV files so that I can use as a model?
Pointdump
Felipe,
"You did the same as I did, as the video. Right?"
Yes, same as you, same results. But I also got the 4 warnings.
Here's some borehole data that works for me in 2017. Attached.
Dave
Dave Stoll
Las Vegas, Nevada
Dave,
I will use the files on Monday in the company I work for.
Whatever the outcome, I will keep you informed.
Thanks again for your attention.
I thank you really.
Felipe
Davi,
Worked perfectly!.
Thank you for the help.
I'm really grateful.
Felipe
Dave,
Worked perfectly!
Thank you for your help.
I am very thankful.
Felipe
tonykhoury
Dave,
Is it possible to use the 2017 geotechnical module with civil 3d 2014 ? or it has be civil 3d 2017 ?
Thank you
Pointdump
Tony,
Good question. I don't know. Maybe you could check with Keynetix Support:
http://www.keynetix.com/support/
Dave
Dave Stoll
Las Vegas, Nevada
