Civil 3D Forum
2017 Geotechnical Module
10 REPLIES 10
Message 1 of 11
852 Views, 10 Replies
Hello!
I need help to solve this problem. I don't understand this behavior. My CSV files are correctly filled.
Information: CSV files, showed no problems on another computer with Civil 3D 2015.
https://www.youtube.com/watch?v=3WnVZsnPA5Q
Thanks!
10 REPLIES 10
Message 2 of 11
Pointdump
Felipe,
Post both CSV files. I'll test it in 2017 and see if I get the same.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Message 3 of 11
in reply to: Pointdump
Hi!
Thanks!
Message 4 of 11
Pointdump
Felipe,
I'm not sure what is going on, but even though it shows the CSV's are "Valid", it's not importing them.
Dave
Dave Stoll
Las Vegas, Nevada
Message 5 of 11
First: thank you for your attention.
You did the same as I did, as the video. Right?
I do not understand the "4 warnings" in your test.
You could send me CSV files so that I can use as a model?
Message 6 of 11
Pointdump
Felipe,
"You did the same as I did, as the video. Right?"
Yes, same as you, same results. But I also got the 4 warnings.
Here's some borehole data that works for me in 2017. Attached.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 11
Dave,
I will use the files on Monday in the company I work for.
Whatever the outcome, I will keep you informed.
Thanks again for your attention.
I thank you really.
Felipe
Message 8 of 11
Davi,
Worked perfectly!.
Thank you for the help.
I'm really grateful.
Felipe
Message 9 of 11
Dave,
Worked perfectly!
Thank you for your help.
I am very thankful.
Felipe
Message 10 of 11
tonykhoury
Dave,
Is it possible to use the 2017 geotechnical module with civil 3d 2014 ? or it has be civil 3d 2017 ?
Thank you
Message 11 of 11
Pointdump
in reply to: tonykhoury
Tony,
Good question. I don't know. Maybe you could check with Keynetix Support:
http://www.keynetix.com/support/
Dave
Dave Stoll
Las Vegas, Nevada
Rail Community
