2016 SP2 and Feature Lines
Message 1 of 27
I am seeing some unexpected behaviour with Feature lines using SP2 for C3D 2016.
A new "Feature" seems to be allowing the feature lines to be "siteless" this is also the default.  Not mentioned in the readme.
I am also getting lots of errors when auditing drawings with feature lines.  Could be the drawing, but it is deleting elevation points.  Maybe this is overly aggressive from the readme:
  • An issue has been resolved where extra vertices were created on some feature lines which impacted the ability to create grading projections from those feature lines. To resolve this issue, run the AUDIT command in any affected drawings after installing the service pack.
These are elevation points that I have created and need.  Please don't delete them!!
Conan Witzel
C3D 2016 SP2 (Maybe unfortunately)
Replies (26)
Message 2 of 27
rkmcswain
Open a support ticket with Autodesk please.
Posting in the forums is good for alerting peers, but issues like this need to get into the system so they can get a fix going. Thanks.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 27
Todd_Rogers
Conan just called me and I tested it.  What happened to mine is the elevation points I manually put in became a grayed out triangle (instead of the circle). So I am going to log this with Autodesk right now.
Todd Rogers
Civil Administration at Walter P Moore
Message 4 of 27
I wanted to make sure it wasn't a drawing specific issue.  I verified with Todd and he will log it for me.  Thats why I still love my reseller!!!
Conan Witzel
Message 5 of 27
Todd_Rogers
It's been logged @Anonymous.  Great catch.  And we that's why we love our customers!!
Todd Rogers
Message 6 of 27
Neilw_05
I've been wishing for siteless featurelines. I hope this is an enhancement and not a bug.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 7 of 27
Todd_Rogers
This was actually tested on a site.
Todd Rogers
Message 8 of 27
Jeff_M
Yes, this is a new feature based on our wishes.
Message 9 of 27
Neilw_05
Jeff, is this documented anywhere?
WIN 10 64 PRO
Message 10 of 27
neilyj666
Is this a wishlist item that has now created a new bug?
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 11 of 27
Todd_Rogers
Like I was saying in my post, I did it on a site.  I don't think it has to do with the new NONE site feature, but then again, it might.  I created mine on a site and it messed it up as soon as I audited.
Todd Rogers
Message 12 of 27
Jeff_M
@Neilw_05, the Readme for SP2 has been updated to include this information.
A change in behavior has been introduced which enables you to create feature lines without specifying a site for them. To create feature lines outside of a site, select the <None> option from the site selection list when you are creating feature lines. Selecting the <None> option adds the feature lines to their own top-level collection on the Prospector tab in Toolspace, underneath the drawing name.
Feature lines that are created outside of a site do not interact with each other, so you do not need to specify the style priority for them like you do with feature lines that exist in the same site. They also do not interact with other objects that they cross, such as alignments, parcels, or survey figures.
There are some restrictions on using these feature lines in previous versions of the software:
  • These feature lines cannot be moved or copied to a site.
  • In a drawing that contains such feature lines, you must create a new site for any new feature lines that you want to add to a site.
Message 13 of 27
Neilw_05
Thanks for the update. How did you find out they updated the readme?
WIN 10 64 PRO
Message 14 of 27
Jeff_M
I reported the missing info, was told they would update the Readme, kept checking back and saw it today.
Message 15 of 27
Timothy_Sean_Hulbert
Here is the official Hot Fix
Civil 3D 2016 SP 2 - Feature Line errors and issues
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
Timothy "Sean" Hulbert, PE
Product Support Specialist
Link Name | Link Name | Link Name | Link Name
Message 16 of 27
fcernst
Sean,
Why does this not show up under Product Updates on our Account? It doesn't show up on Application Manager either.
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Message 17 of 27
neilyj666
Productivity Pack 2 is also missing from the Product Enhancements section; although it popped up in Application Manager yesterday even though it was released on 18th Jan
Message 18 of 27
fcernst
I don't see anything this morning for a Productivity Pack 2. Do people have this installed?
Fred Ernst, PE
C3D 2026
Ernst Engineering
Message 19 of 27
MehwashAbbas-WPM
I was able to follow the link from Sean and install the hotfix. Thanks, Sean for posting this.
Message 20 of 27
fcernst
Yes, I have the Hotfix installed..I was wondering about the Productivity Pack 2.
Fred Ernst, PE
C3D 2026
Ernst Engineering
