feature line direction arrow label
CLG1972
Message 1 of 9
CLG1972
Is there a way to direction arrow point to the lowest point dynamically. I have labels on my feature line which update automatically, however the direction arrows are all the same direction.
Replies (8)
Message 2 of 9
troma
You need an expression.
Something like this:
Give it a good name like "direction of flow"
Then in your label style composer, for the rotation of the arrow choose "direction of flow".
BTW I use a Block for my flow arrow, not the "Direction Arrow" option within the label. I can't remember if it's possible to rotate that one or not.
Mark Green
Working on Civil 3D in Canada
Message 3 of 9
Maine-iac
Thanks Mark this worked great for me. Usually relied on building the surface from feature lines then doing two point surface slope labels. Now I can skip the surface build and label all the segments of a feature line by using the multi segment feature line labeling. Would hope that original poster "CLG1972" would accept this as a solution. I almost didn't view this post as it was not accepted as a solution.
Civil 3D 2022.1
Windows 10 x64
HP ZBook 15 G5
Intel(R) Core(TM) i7-8750H CPU @ 2.60GHz
32 GB RAM
Message 4 of 9
BrianHailey
For those that aren't aware, the default template that ships with Civil 3D has this expression in it already.
2016-09-02_0901
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
Message 5 of 9
troma
I did not know that. Which year did that start in?
Had to figure this out for myself (after being informed that it wasn't possible).
Mark Green
Message 6 of 9
BrianHailey
I don't know, about a decade ago?
GEI Consultants
My Civil 3D Blog
Message 7 of 9
troma
Well maybe our company template was set up wrong. Because it certainly didn't have any expressions in it. The only styles for everything were 'Standard' and 'Basic' until we made our own.
Mark Green
Message 8 of 9
BrianHailey
Back in the day (I believe prior to 2009/2010 or thereabouts) Civil 3D shipped with multiple templates. Something like "Basic", "Expanded", and "LandDesktop". Later they combined them all into one template. Sounds like your company started with the "Basic".
GEI Consultants
My Civil 3D Blog
Message 9 of 9
CLG1972
I was finally able to try this out and was able to get it to work. Thanks for the solution and I am sorry I was not able to answer sooner.
