Pipe Network in Profile view
Hello ,
i am having a problem adding part to a profile view , i only want to add some parts not the whole network , but some how after i select those parts and go the profile view it select the other parts automatically and add them all !! its causing me a duplicate , because i have to paralle lines with diffrent alignments but some how it mixes them in the same network !! what should i do ??
Rana
civilman1957
When you select the parts, there's an option for selected parts only...enact your command, then type "S" in, and it will insert only the parts you select...
Cad Manager/Senior Engineering Technician
Autodesk Certified Professional
Intel(R) Core (TM) i7-7700 CPU
3.60 GHz/24 GB BEAST
Civil 3D 2013/2014/2017/2018/2020
it worked !! thank you very much 🙂
troma
When you run the command, do you immediately select the parts?
First, you should choose the option "Selected parts only" option, then pick the parts you want. Or maybe you're already doing that?
You can also go into the profile view "Pipe networks" tab and deselect the parts that you don't want to show.
Mark Green
Working on Civil 3D in Canada
civilman1957
You're very welcome..and make sure, always, to mark a response that solved your problem as a solution, so others can use it for their situation, as well...have a great day...
troma
Well, I was late again 😉
Mark Green
civilman1957
Gotch yer back, brother 🙂
