Hi @eirij , do you want to convert a pressure network into a 3D solid?
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
@eirij , if that is the case you can convert your C3D pressure network or pipe Network to solid using this command CONVERTTO3DSOLIDS, you will need to be in an isometric view and then call the command.
Tatiana Machado
Hi @tmachado,
Thank you for your reply. The problem is that I would like to get the solids from the API, read the 3D information along with pressure pipe network information and that's all. However, the solids from CONVERTTO3DSOLIDS doesn't contain the information about the pressure pipe network or you can say solids are without any properties. Where the classes Structure & Pipe contains Solid3dbody information.
So Is there any other way to get the solid3d bodies of the PressurePipe or PressureFitting?
Best Regards,
Muhammad Eirij
Hi @eirij , unfortunately no, what do you need this for?
Sadly you will need to convert your network in a solid and then add the data as property set data
Tatiana Machado
Cool, I have my own issues with property sets, you can't reach any C3D properties through wish is a problem, then you can assign property set to any ACAD object that exists but it is no way to get that information on a label or text if it is not associated to a C3D object
Tatiana Machado
With an update in Civil3D 2021.2, there is an update in PressurePipe API. Now there is a function available to get the solid body of a PressurePart. 😊
