Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
I need a lisp routine to change the abbreviations in drawing settings
2 REPLIES 2
Shubz26
798 Views, 2 Replies
Shubz26
I need a lisp routine to change the abbreviations in drawing settings. Anyone have one, or any guidance on how I can create one. I've never written a lisp before, I tried now but couldn't even get mine to run the EDITDRAWINGSETTINGS command.
Civil 3D 2020
Intel Xeon CPU W3550 @ 3.07GHz
Nvidia Quadro 2000
25GB RAM
Windows 7 Enterprise 64 Bit
Civil 3D 2020
Nvidia Quadro 2000
25GB RAM
2 REPLIES 2
hippe013
in reply to: Shubz26
hippe013
The following should help you get going. It demonstrates how to drill down to the abbreviation settings and how to set the values. I'll leave the rest up to you.
(defun c:test ()
  (setq ad (_GetAeccDocument)) ;Get the Aecc Document
  (setq s (vlax-get-property ad 'Settings)) ;Get the aecc settings from the Aecc Document
  (setq ds (vlax-get-property s 'DrawingSettings)) ;Get the Drawing Settings from the aecc settings
  (setq as (vlax-get-property ds 'AbbreviationSettings)) ;Get the abbreviation settings from the drawing settings
  (setq alignAbbrev (vlax-get-property as 'AlignmentAbbreviations)) ;Get the Alignment abbreviations from the abbreviation settings
  (setq alignBeg (vlax-get-property alignAbbrev 'AlignmentBeginning)) ;Get the alignment beginning abbreviation from the alignment abbreviations
  (princ (strcat "\nCurrent AlignmentBeginning Abbreviation: " alignBeg)) ;Print the current value of the alignment beginning abbreviation
  (vlax-put-property alignAbbrev 'AlignmentBeginning "BEG") ;Set the value of the Alignment Beginning abbreviation
  (princ (strcat "\nNew AlignmentBeginning Abbreviation: " (vlax-get-property alignAbbrev 'AlignmentBeginning))) ;Print the new value of the alignment beginning abbreviation
  (princ) ;exit clean
(defun _GetAeccDocument ()
  (setq C3D (strcat "HKEY_LOCAL_MACHINE\\" (if vlax-user-product-key (vlax-user-product-key) (vlax-product-key) ) )
	C3D (vl-registry-read C3D "Release")
	C3D (substr C3D 1 (vl-string-search "." C3D (+ (vl-string-search "." C3D) 1)))
	C3D (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AeccXUiLand.AeccApplication." C3D)))
  (vlax-get-property C3D 'ActiveDocument)
(defun c:test ()
  (princ) ;exit clean
Shubz26
in reply to: hippe013
Shubz26
Thanks a million for this!
It took a while to figure out, but I managed to get it to change all the abbreviations I needed to.
Civil 3D 2020
Nvidia Quadro 2000
25GB RAM
Civil 3D 2020
Nvidia Quadro 2000
25GB RAM
Rail Community
