Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Verify Origin Point
1 REPLY 1
arpenteur
692 Views, 1 Reply
Verify Origin Point
I am looking for the command to know if the Origine Point is really at 0,0,0 before Paste To Original Coordinates?
1 REPLY 1
moogalm
in reply to: arpenteur
When you use _COPYBASE with certain base point, the selected objects are copied in to a temp destination drawing, this temp drawing holds the INSBASE sysvar with given base point.
This program attempts to tap that when you perform a _PASTEORG in another drawing.
 public class EntryPoint : IExtensionApplication
        public void Initialize()
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var curDb = HostApplicationServices.WorkingDatabase;
            var docs = Application.DocumentManager;
            docs.DocumentCreated += Docs_DocumentCreated;
            docs.DocumentToBeDestroyed += Docs_DocumentToBeDestroyed;
        private void Docs_DocumentToBeDestroyed(object sender, DocumentCollectionEventArgs e)
            MyCommands.DisableDBEvents(e.Document.Database);
        private void Docs_DocumentCreated(object sender, DocumentCollectionEventArgs e)
            MyCommands.EnableDBEvents(e.Document.Database);
        public void Terminate()
    public static class MyCommands
       //Utils:
        public static void PrintToCmdLine(string str)
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage(str);
        public static string ObjToTypeAndHandleStr(DBObject dbObj)
            Debug.Assert(dbObj != null);
            string str1 = dbObj.GetType().Name;
            return string.Format("< {0,-20} {1,4} >", str1, dbObj.Handle.ToString());
        public static string ObjToTypeAndHandleStr(ObjectId objId)
            string str;
            if (objId.IsNull)
                str = "(null)";
            else
                // open up even if erased
                Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = objId.Database.TransactionManager;
                using (Autodesk.AutoCAD.DatabaseServices.Transaction tr = tm.StartTransaction())
                    DBObject tmpObj = tr.GetObject(objId, OpenMode.ForRead, true);
                    str = ObjToTypeAndHandleStr(tmpObj);
                    tr.Commit();
            return str;
        public static string PtToStr(Point3d pt, DistanceUnitFormat unitType, int prec)
            string x = Converter.DistanceToString(pt.X, unitType, prec);
            string y = Converter.DistanceToString(pt.Y, unitType, prec);
            string z = Converter.DistanceToString(pt.Z, unitType, prec);
            return string.Format("({0}, {1}, {2})", x, y, z);
        public static void EnableDBEvents(Database db)
            db.BeginDeepClone += CurDb_BeginDeepClone;
            db.BeginInsert += Db_BeginInsert;
        public static void DisableDBEvents(Database db)
            db.BeginDeepClone -= CurDb_BeginDeepClone;
            db.BeginInsert -= Db_BeginInsert;
        private static void Db_BeginInsert(object sender, BeginInsertEventArgs e)
            Database db = e.From;
            PrintToCmdLine("Insert origin Point"+ PtToStr(db.Insbase, DistanceUnitFormat.Current, -1));
        private static void CurDb_BeginDeepClone(object sender, IdMappingEventArgs e)
            if (e.IdMapping.DeepCloneContext == DeepCloneType.Explode)
                IdMapping idMap = e.IdMapping;
                System.Collections.IEnumerator iter = idMap.GetEnumerator();
                while (iter.MoveNext())
                    IdPair pair = (IdPair)iter.Current;
                    try
                        StringBuilder sb = new StringBuilder(ObjToTypeAndHandleStr(pair.Key));
                        sb.Append(pair.Key.ToString());
                        sb.Append("\n" + pair.Value.ToString());
                        sb.Append("\n" + pair.IsCloned.ToString());
                        sb.Append("\n" + pair.IsPrimary.ToString());
                        sb.Append("\n" + pair.IsOwnerTranslated.ToString());
                        PrintToCmdLine(sb.ToString());
                    catch (Autodesk.AutoCAD.Runtime.Exception ex)
                        PrintToCmdLine("Couldn't add a pair from the map: " + ex.Message);
Rail Community
