Surface .NET Automatic rebuild.
Hello, how can I set or get automatic rebuild property for surface using .NET or COM?
I watched this post, but it's don't helpful for me.
http://forums.autodesk.com/t5/autocad-civil-3d-customization/surface-net-api-amp-rebuild/td-p/391853...
Thanks.
Jeff_M
This property is not exposed in either API
BlackBox_
Hi @TimYarris -
Please confirm; can we still not modify a Surface's 'Rebuild-Automatic' option using Civil 3D 2019 .NET API?
Cheers
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
zrobert
Hi;
In documentation I only found in Autodesk.Civil.Settings namespace, SettingsSurface.SettingsDefaults.AutoRebuild Property, but as read only property.
Civil3DReminders_com
So sad, 6 years later and Autodesk still sucks at supporting an API. Worse thing is that the Rebuild() method on a surface doesn't Rebuild a surface in Civil 3D 2024 and a user needs to manually do it.
Horrible customer service.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
