How find out space status of a viewport ?
mehdi-guida
mehdi-guida
I have 4 viewports in a layout. Space of One of them is Model (highlighted and is in model space).
Is there any system variable or .Net code to find out which one is in mode space and which one is in paper space?
Thank you
Jeff_M
Editor.ActiveViewportId;
I would first check the CVPORT system variable. If it is 1 then no viewports are currently active in modelspace.
mehdi-guida
Thank you for reply.
As you said If CVPORT is 1 then no viewports are currently active in modelspace. but I need to know which one is active?
Jeff_M
@mehdi-guida wrote:
...but I need to know which one is active?
Then use the Editor.ActiveViewportId; property...
mehdi-guida
Thank you
I used this property but that always return an ObjectId even in empty layout !
Jeff_M
The Layout is a Viewport. That is why CVPORT will return 1 when no viewports are active to modelspace. And also why I said you should check that sysvar.
mehdi-guida
Thank You again for your all answers. You helped me a lot.
Do you have any idea about finding current Mtext annotation scale? (below link)
https://forums.autodesk.com/t5/civil-3d-customization/get-annotation-scale-of-mtext/td-p/12624478
Thank You
Mehdi
