Get Annotation Scale of Mtext
mehdi-guida
Message 1 of 10
mehdi-guida
Hi
How can I get annotation scale (of mtext) by .net?
Replies (9)
Message 2 of 10
Jeff_M
@mehdi-guida I'm not sure if this is the best way to do it, but it seems to work on the Mtext objects I've tested with.
        [CommandMethod("ShowMtextAnnoScale")]
        public void showmtextscale()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var db = doc.Database;
            var entPrompt = new PromptEntityOptions("\nSelect an Mtext:");
            entPrompt.SetRejectMessage("...not an Mtext object.");
            entPrompt.AddAllowedClass(typeof(MText), true);
            var entSel = ed.GetEntity(entPrompt);
            if (entSel.Status != PromptStatus.OK)
                return;
            ObjectContextManager ocm = db.ObjectContextManager;
            ObjectContextCollection occ = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var mtext = (MText)tr.GetObject(entSel.ObjectId, OpenMode.ForRead);
                if(mtext.Annotative == AnnotativeStates.False)
                    ed.WriteMessage("\nSelected Mtext not annotative!");
                    return;
                //the ObjectContexts class is in the Autodesk.AutoCAD.Internal namespace
                var oContexts = ObjectContexts.GetContexts(mtext, occ.Name);
                var scale = "";
                foreach( var context in oContexts )
                    if (context.Name == occ.CurrentContext.Name)
                        scale = occ.CurrentContext.Name;
                        break;
                    scale = oContexts[0].Name;
                ed.WriteMessage("\nSelected Mtext has the current annoscale of {0}.", scale);
Jeff_M, also a frequent Swamper
Message 3 of 10
mehdi-guida
Thank You So So So much for reply.
The only error I couldn't solve that is :
Message 4 of 10
hippe013
Add the following:
Using Autodesk.AutoCAD.Internal;
Message 5 of 10
mehdi-guida
Thank you
I already used that. but its color shows it never used.
Message 6 of 10
hippe013
Thats weird. What year software are you using?
Do you have a reference to the Acmgd.dll?
Message 7 of 10
mehdi-guida
No, but when I add Acmgd.dll the Acdbmgd.dll automatically will be removed and I get a lot of error.
Message 8 of 10
hippe013
That does seem strange. Again, what year AutoCAD are you referencing?
Here are the references that I use and I do not have any issues.
Message 9 of 10
mehdi-guida
I removed references and added them again and everything OK now. Thank you 🙂
Message 10 of 10
mehdi-guida
Thank you so much my Hero 🙂
