CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Displaying Streamlines - Post Processing
10 REPLIES 10
Message 1 of 11
2131 Views, 10 Replies
I reviewed all of the tutorials, and I still cannot figure out how to post-process visual streamlines (e.g., velocity streamlines) for my model.  I am using the 2013 edition.  Thank you.
10 REPLIES 10
Message 2 of 11
ilyas_drawbridge
Perhaps, you can go to the wikihelp page and search for traces.  Basically, you will need to create a results plane and put seed points for your particle traces.
Regards
Ilyas
Message 3 of 11
in reply to: ilyas_drawbridge
Is it possible to draw streamline in surface model or 2D models through trace or something?
Tags (2)
Message 4 of 11
Jon.Wilde
The above post is your answer regarding streamlines.
Although, you are showing vectors rather than streamlines. These are generated from a cut-plane, there's a handy page in the help here.
Kind regards,
Jon
Message 5 of 11
in reply to: Jon.Wilde
Thanks for your reply but you can see in image i posted earlier that i am working on a 2D model and when i click on planes , trace option is off. I want to know any option for tracing streamline (not vectors) for 2D models.
Tags (2)
Message 6 of 11
Jon.Wilde
Ah I see, understood.
In that case no, unfortunately there is no option for these in 2D, they are available only for 3D analyses.
Best regards,
Jon
Sent from my iPhone
________________________________
Autodesk Limited
Registered Office: One Discovery Place, Columbus Drive, Farnborough, Hampshire GU14 0NZ
Registered in England and Wales, No. 1839239
Message 7 of 11
well autodesk has been doing good job, hope there will be something like this in future. thanks.
Message 8 of 11
Jon.Wilde
Could I suggest you pop a request into our Idea Station here?
http://forums.autodesk.com/t5/simulation-cfd-ideastation/idb-p/82
This way we can all vote on it and the developers will know it has been requested 🙂
Thanks!
Jon
Autodesk Limited
Message 9 of 11
srhusain
A way to show the streamlines for a 2D model is to
  1. Before solving, select stream function as a result from the results dialog box (from the solve widget)
  2. After solving, turn on the stream function fringe results
  3. Right click on the stream function results legend and turn on the contours
See attached image.
Message 10 of 11
in reply to: srhusain
Thanks a lot. This will fulfill my purpose but how did you get stream function option in global result. Is it available in 2013 version or higher version?
Message 11 of 11
ok got it finally. thanks !
Technology Administrators
